Knowledge Base Article
Why do I see different Stratix® 10 Quartus® Prime Pro Edition Software generated DDR4 IBIS pin model at same bus signals ?
Description
This is expected in the DDR4 IBIS model generated from Quartus® Prime Pro Edition Software.  The IBIS model is based on pin location and function in the design.
In the x8/9 design, some of the DQ or Address/Command pins are located on a pin supporting DQS functionality (in x4 interfaces).
The physical properties of the I/O pins that support both DQ and DQS functions are slightly different than the pins that only support DQ functions, so Quartus® Prime Pro Edition Software uses different models to improve the accuracy of the simulation.
Resolution
This is an example DDR4  IBIS model generated from Quartus® Prime Pro Edition Software. You can see the mem_a(14) and mem_a(13) pins are assigned to the DQS functionality pin and have a different IBIS model name than other mem_a pins.
mem_a(14)~pad             sstl12_rtio_r34cp1_dqs_lv
mem_a(13)~pad             sstl12_rtio_r34cp1_dqs_lv
mem_a(12)~pad             sstl12_rtio_r34cp1_lv
mem_a(16)~pad             sstl12_rtio_r34cp1_lv
mem_a(15)~pad             sstl12_rtio_r34cp1_lv
mem_a(2)~pad               sstl12_rtio_r34cp1_lv
mem_a(6)~pad               sstl12_rtio_r34cp1_lv
mem_a(0)~pad               sstl12_rtio_r34cp1_lv
mem_a(3)~pad               sstl12_rtio_r34cp1_lv
mem_a(7)~pad               sstl12_rtio_r34cp1_lv
mem_a(1)~pad               sstl12_rtio_r34cp1_lv
Updated 7 days ago
Version 2.0
