Knowledge Base Article
Why do I see design Assistant Warning messages for the Agilex® 5 FPGA device with GTS HDMI IP Design Example when using the Quartus® Prime Pro Edition Software version 24.2?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2 when compiling the GTS HDMI IP Design Example, you may observe High Severity warnings in Quartus® Design Assistant.
This warning doesn’t affect design functionality and can be ignored.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 4 months ago
Version 7.0
