Knowledge Base Article
Why do I observe a bit mismatch on RX parallel data for the GTS CPRI PHY IP when selecting CPRI rates of 9.8 Gbps, 6 Gbps, or 2.4 Gbps?
Description
Due to an issue with the FastSim model in Quartus® Prime Pro Edition software version 25.3.1, selecting CPRI speeds of 9.8 Gbps, 6 Gbps, or 2.4 Gbps may result in a bit mismatch on the RX parallel data.
Resolution
To work around this issue, comment out the following line in the files run_riviera.do, run_vcsmx.sh, and run_vsim.do located in the generated example design example_testbench folder:
  • FAST_SIM_OPTIONS="+define+IP7521SERDES_UX_SIMSPEED"
This issue is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 6 months ago
Version 2.0
