Knowledge Base Article
Why do I get the following error during the Quartus® II Analysis & Synthesis when upgrading an Avalon-MM Stratix V Hard IP for PCI Express IP core design from version 12.1 to v13.0?
Description
Error (12077): Node instance "auto_hub" instantiated with unknown parameter "BROADCAST_FEATURE."
Error (12154): Can't elaborate inferred hierarchy "sld_hub:auto_hub"
There is an issue when creating a Quartus® II archive. All megafunctions with the prefix sld_ are associated with the specific Quartus® II version that they were generated with.
Resolution
Remove the ./megafunctions folder from the archive.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
