Knowledge Base Article
Why do I get bad performance when compiling vector add example design with Intel® FPGA SDK for OpenCL™?
Description
Due to a problem in the Intel® FPGA SDK for OpenCL™ version 18.1 and later,  you may get bad performance when you compile the same vector_add example design code. The performance is as follows.
Performance
V16.1
V18.0
V18.1
V19.1
~3ms
~3ms
~170ms
~170ms
Resolution
To work around this problem, add an attribute  to vector_add.cl which sets the required work group size.
  __attribute__((reqd_work_group_size(1, 1, 1)))
  __kernel void vector_add(__global const float *x,
                           __global const float *y,
                           __global float *restrict z)
      // get index of the work item
      int index = get_global_id(0);
      // add the vector elements
      z[index] = x[index] y[index];
The problem is scheduled to be fixed in a future release of the the Intel® FPGA SDK for OpenCL™.
Updated 11 months ago
Version 4.0
