Knowledge Base Article
Why do F-tile Reference and System PLL clocks Intel® FPGA IP fail to lock at specific frequencies?
Description
Due to a problem in In the Intel® Quartus® Prime Pro Edition Software versions 22.2 and earlier, you might observe the F-tile Reference and System PLL clocks Intel® FPGA IP fails to lock at:
  • 999.9 MHz with the reference clock frequency set as 323.2 MHz.
  • 506.88 MHz with the reference clock frequency set as 245.76 MHz.
Resolution
To work around this problem, you need to do the following steps:
  1. In the project navigator, double-click the OPN (ordering part number).
  2. In the pop-out window, click the “Device and Pin Options” button.
  3. In the “General” category, change the “Configuration clock source” parameter from “Internal Oscillator” to:
  • 100 MHz OSC_CLK_1 pin, or
  • 125 MHz OSC_CLK_1 pin
  1. Recompile the design.
  2. Provide an external reference clock with the correct frequency to the OSC_CLK_1 pin. The “OSC_CLK_1” pin location can be found in the schematics of your development kit.
Note: for Intel Agilex® F-tile devices with OPNs that end with the suffix VR0, VR1, and VR2, you need to use Intel® Quartus® Prime Programmer version 21.4 to get the above workarounds working.
Updated 11 months ago
Version 3.0
