Knowledge Base Article
Why can the P-Tile Avalon® Streaming IP for PCI Express* driver not be installed?
Description
Due to a problem with the P-tile Avalon® Streaming IP for PCI Express* drivers, you might not be able to install the drivers in CentOS 7.
Resolution
Use the P-Tile Avalon® Streaming IP for PCI Express* PIO example design drivers as a template and adapt them to your IP instance before recompiling.
Ensure that the platform that you are using meets the Hardware and Software requirements presented on the P-tile Avalon® Streaming IP for PCI Express* Design Example User Guide.
Updated 5 months ago
Version 5.0No CommentsBe the first to comment
