Knowledge Base Article
Why can’t I achieve a timestamp accuracy of +/- 3.0nSec with the 10GE or 25GE F-Tile Ethernet FPGA Hard IP variant with the “Enable IEEE 1588 PTP” parameter enabled and the “Timestamp accuracy mode” parameter set to “Basic”?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the 10GE or 25GE F-Tile Ethernet FPGA Hard IP variants with the “Enable IEEE 1588 PTP” parameter enabled, and the “Timestamp accuracy mode” parameter set to “Basic” might fail to achieve a timestamp accuracy of +/- 3.0nSec. The best timestamp accuracy for these variants that can be achieved in this mode is +/- 4.0nSec.
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.1.
Updated 3 months ago
Version 2.0
