Knowledge Base Article
Why are there functional errors on an IO pin in my Agilex™ 5 design?
Description
Due to a problem in the Quartus® Prime Edition Software version 24.1, you might see functional errors on an IO pin in Agilex™ 5 designs. A timing error causes this problem, so that it will depend on voltage and temperature. The problem only affects Agilex™ 5  devices.
Resolution
To work around this problem, download and install the patches below for the Quartus® Prime Pro Edition Software version 24.1
This problem is fixed starting with the Quartus® Prime Pro Edition Software version 24.3.
Updated 8 months ago
Version 3.0
