Knowledge Base Article
Why are there functional errors in my Simple Quad-port mode M20K RAM?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software, you may see functional errors in your Simple Quad-port RAM mode M20K when targetting Intel® Stratix® 10 devices.
This is caused by a glitch on the wren_a which results in an unintentional write to the address on the waddr_a port with the data on the wdata_a port. The glitch can occur when to disable wren_b is low and rden_a is high.
Only the Simple Quad-port RAM mode of the M20K embedded memory is affected by this problem, all other modes are unaffected.
Resolution
To work around this problem for projects targetting Intel® Stratix® 10 FPGA Smart VID extended temperature grade devices, download and install the patch according to the versions of your Intel® Quartus® Prime Pro Edition Software.
This problem is fixed for Intel® Stratix® 10 FPGA Smart VID extended temperature grade devices (-E1V, -E2V and –E3V) beginning with version 20.2 of the Intel® Quartus® Prime Pro Edition Software.
Simple Quad-port RAM mode for M20Ks is no longer supported for the following devices
    All Intel® Stratix® 10 Smart VID industrial grades devices (-I1V, -I2V, and -I3V)
    All Intel® Stratix® 10 fixed voltage devices (-E2L, -E3X, -I2L, -I3X, and –C2L)
If your design contains the Simple Quad-port mode M20K RAMs for any of the above devices, the Intel® Quartus® Prime Pro Edition Software will output an error message from v21.4. Your design will no longer go through the compile flow until you have removed the Simple Quad-port mode RAM from your design.
To check for Simple Quad-port mode RAMs in the design, a script (check-simple-quad-port-memory-usage.tcl) is provided. To use this script, in the command line where quartus_cdb is accessible, cd to the top level project, and type:
quartus_cdb -t check-simple-quad-port-memory-usage.tcl
Additional Information
In the Intel® Quartus® Prime Pro Edition Software v21.4, designs that contain Simple Quad-port mode M20K RAMs in the following devices will incorrectly output an error message and not complete the compilation:
  • 1SD21BPTxxxxExVGxx
  • 1SD110PJxxxxExVGxx
  • 1SD280PTxxxxExVGxx
A patch is scheduled to be released to re-enable the compilation of these devices when the design includes Simple Quad-port mode M20K RAMs.
To re-enable these devices, download and install the appropriate patch from the following links:
Updated 8 months ago
Version 3.0
