Knowledge Base Article
Why are the VOD, pre-emphasis, and slew rate parameters reported as -1 for Stratix® V, Arria® V, and Cyclone® V FPGA transceiver pins in the Resource Property Editor when using Quartus® II software version 13.0 and 13.0sp1?
Description
Due to a bug in Quartus® II software versions 13.0 and 13.0sp1, VOD, pre-emphasis, and slew rate parameters are incorrectly reported as -1 for Stratix® V, Arria® V, and Cyclone® V FPGA transceiver pins in the Resource Property Editor.
Resolution
You can refer to the fitter results for the assigned VOD, pre-emphasis, and slew rate parameters.
This problem has been resolved in the Quartus II software version 13.1 and onwards.
Updated 11 months ago
Version 3.0
