Knowledge Base Article
Why are the SDC constraints for link clocks generated by the GTS JESD204B FPGA IP inaccurate?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 24.3, you may observe incorrect SDC constraints for link clocks generated by the GTS JESD204B FPGA IP.
Resolution
To work around this problem, update the value of period in the following constraints in ip/intel_jesd204b_gts_phy_<version>/synth/j204b_gts.sdc:
create_clock -name "rxlink_clk" -period <period>ns [get_ports rxlink_clk]
create_clock -name "txlink_clk" -period <period>ns [get_ports txlink_clk]
where <period> is the calculated value of 1/(data rate/40).
This problem has been fixed in the Quartus® Prime Pro Edition software version 24.3.1.
Updated 3 months ago
Version 3.0
