Knowledge Base Article
Why are the Ax, Ay, Az, and Chainin ports missing from the block symbol and HDL instantiation template of the Intel® Stratix® 10 Native Floating Point DSP IP?
Description
Due to a problem with the Intel® Stratix® 10 Native Floating Point DSP IP in Intel® Quartus® Prime Pro software version 17.1, you may observe that the Ax, Ay, Az, and Chainin ports are missing from the block symbol and HDL instantiation template if the IP is configured with Vector Mode 2.
Resolution
This problem has been fixed starting in v18.0 of the Intel Quartus Prime Pro software.
Updated 1 month ago
