Knowledge Base Article
Why are setup timing violations reported on the F-Tile Support Logic and Direct PHY paths?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1.1, you may observe setup timing violations on clocks associated with F-Tile support logic and Direct PHY paths. The failing path was between Soft Reset Controller (SRC) and Direct PHY (DPHY) logic due to synchronizer problem.
Resolution
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 2 months ago
