Knowledge Base Article
Why am I seeing Riviera* simulation failures for the F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) and Dynamic Reconfiguration enabled designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1.1, you may see Riviera* simulation failures for the F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) and Dynamic reconfiguration enabled designs. This failure is seen for 400GE-8 and 100GE-4 AN/LT Dynamic Reconfiguration example designs.
Resolution
For workaround, go to your ‘<design_example_dir>\example_testbench>’ folder and update the ‘run_rivierasim.do’ script as below:
1) Update the below line
set USER_DEFINED_VERILOG_COMPILE_OPTIONS "+define+BK_FASTSIM_MODEL -err VCP2675 W1
To :
set USER_DEFINED_VERILOG_COMPILE_OPTIONS "+define+INTC_SIM_AN_LT_ENABLE +define+GDR_TURNOFF_FASTSIM -err VCP2675 W1
2) Update the below line
vlog +define+DR_F_GAVMM_SPEEDUP basic_avl_tb_top.sv eth_f_hw.v -f ./common_files_list.f
To :
vlog basic_avl_tb_top.sv eth_f_hw.v -f ./common_files_list.f
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.3.
Updated 4 months ago
Version 4.0
