Knowledge Base Article
Why am I seeing optimized simulation failure for the F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) and Dynamic Reconfiguration enabled designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1.1, you may see optimized simulation failure for the F-tile Ethernet Hard IP with Auto-Negotiation and Link Training (AN/LT) and Dynamic Reconfiguration enabled designs. This failure is seen for the 400G-8 Example Design variant that has optimized simulation option enabled in the Quartus GUI parameter.
Resolution
For workaround for this problem for optimized simulation in the Quartus® Prime Pro Edition software version 25.1.1, you will need to set LT failure response =1 at the beginning of your simulation testbench.
Register Address
Bit
Name
Description
0x2c0
12
LT failure response
1 = Upon LT failure, PHY will go to data-mode
0 = Upon LT failure, PHY will restart AN if AN is enabled, else PHY will restart LT
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.3.
Updated 4 months ago
Version 4.0
