Knowledge Base Article
Why am I seeing an error “read Ethernet ANLT channel 0 register anlt_ltstat_csr6” or link training failure during hardware testing when using F-tile Dynamic Reconfiguration Suite IP with Auto-negotiation and Link Training (AN/LT) enabled?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3, you may see an error during hardware testing when using the F-Tile Dynamic Reconfiguration Suite IP with Auto-negotiation and Link Training (AN/LT) enabled, and if user logic is enabled.
The error may look like below:
Resolution
For a workaround, follow the steps below:
- ) Navigate to “../[example design]/hardware_test_design/hwtest/tests/ftile_eth_dr_test.tcl”
- ) Search for “Setting sequencer reset” code
- a) For FGT designs, comment line #386 as shown below:
- b) For FHT designs, modify line #386 as shown below:
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.1.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
