Knowledge Base Article
Why am I observing failures to read base Channel 0 in a multi-lane design for the GTS Serial Lite IV IP?
Description
Due to a problem in the Avalon® Memory-Mapped (AVMM) decoder, for a multi-lane GTS serial lite IV IP design, if you perform read transactions on channel N first, then read base channel 0, you might observe that the AVMM interface will hang.
Single-lane designs and write transactions are not affected. However, this may affect the configuration of internal loopback mode.
Resolution
There is no workaround available. You are recommended not to initiate read transaction on channel 0 after reading channel N.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 4 months ago
Version 4.0
