Knowledge Base Article
Why am I observing Design Closure Summary Fail In F-Tile IP Example Designs?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1.1, you might observe the following Design Closure Summary Fail:
  • Design Assistant Summary: Medium Severity Violations
  • Unconstrained Paths: Fail
The following F-Tile IP example designs are impacted by this issue:
  • F-Tile Ethernet IP Dynamic Reconfiguration Example Design
  • F-Tile Interlaken IP Example Design
  • F-Tile MACsec IP Example Design
Resolution
There is no workaround.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 3 months ago
Version 5.0
