Knowledge Base Article
Why am I experiencing compilation failures with the F-Tile Ethernet Hard IP design when the Ethernet mode is set to 25GE-1 variant and the FEC mode is configured as IEEE 802.3 RS(544,514)?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3, the F-Tile Ethernet Hard IP GUI will not prompt any error message when you have the following settings:
  • Ethernet mode: 25GE-1
  • FEC mode: IEEE 802.3 RS(544,514)
The 25GE-1 variant does not support RS(544,514) FEC. Although the F-Tile Ethernet Hard IP failed to detect this error during IP generation, you will observe a compilation failure during the "Support-Logic Generation" stage.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.1.
Updated 3 months ago
Version 6.0
