Knowledge Base Article
What is the correct number of reconfiguration interfaces required for a XAUI PHY IP when using Stratix V, Arria V, and Cyclone V transceiver devices?
Description
The correct number of reconfiguration interfaces required for a XAUI PHY IP when using Stratix® V, Arria® V, and Cyclone® V transceiver devices is five.
The XAUI PHY IP MegaWizard™ implements the PHY in bonded mode and requires four reconfiguration interfaces for each of its channels, plus one interface for a single Tx PLL.
The Quartus® II software version 13.0 and earlier XAUI PHY IP MegaWizard message pane incorrectly advises the required number of reconfiguration interfaces to be eight, which is correct for an unbonded PHY.
Resolution
This problem with the XAUI PHY IP MegaWizard will be corrected in a future version of the Quartus II software.
Related Articles
Updated 11 months ago
Version 3.0
