Knowledge Base Article
Warning: CONV_INTEGER: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, and it has been converted to 0.
Description
You may get this warning when simulating some DSP Builder® designs under Modelsim®. These warning messages do not have any effect on your simulation results, and can be ignored.
Resolution
These warnings (and all others like them) can be suppressed by either of two methods:
- Suppress via Modelsim GUI:
- Open the Simulation dialog box (Options menu).
- Set the option Suppress Warnings from Synopsys Packages to On.
- Click OK.
- Search for the *_atb.do file in your project directories, look for the comment "Disable some warnings ...", and comment out a later line as follows:
# Disable some warnings that occur at the very start of simulation
quietly set StdArithNoWarnings 1
run 0ns
# quietly set StdArithNoWarnings 0
run -all
Related Articles
- ASSERT/WARNING from package ieee.STD_LOGIC_ARITH, Built-in function result set to 'X' due to a ('U', 'X', 'W', 'Z', '-') in an operand / Built-in function CONV_INTEGER/TO_INTEGER argument too large
- Warning: CONV_INTEGER: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, and it has been converted to 0! (ModelSim, VHDL Output File (.vho))
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
