Knowledge Base Article
Warning (10034): Output port "phout" at altera_pll.v(275) has no driver
Description
You may see this warning in the Quartus® II software version 12.1 for designs that use the Altera_PLL megafunction. The phout port is used when the fPLL is configured as a TXPLL for the transceivers. If you do not enable this port in the Altera_PLL megafunction in your design, the warning may still be generated during compilation.
Resolution
You can safely ignore this warning. It is generated by mistake.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
