Knowledge Base Article
The F-Tile HDMI FPGA IP Design and the F-Tile Architecture and PMA and FEC Direct PHY IP with “HDMI” configuration rule are not of production quality.
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1.1 , the F-Tile HDMI FPGA IP Design and the F-Tile PMA/FEC Direct PHY Intel FPGA IP with “HDMI” configuration rule are not completely compliant with the HDMI receiver specifications.
Do not use these IP cores in production designs. However, these IP cores can be used for hardware evaluation and simulation.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
