Knowledge Base Article
Stratix V QDR II and QDR II SRAM Controller with UniPHY and RLDRAM II Controller with UniPHY Memory Interfaces May Exhibit Write Timing Failure
Description
Memory interfaces targeting Stratix V devices may exhibit write setup or write hold timing failures.
Resolution
A workaround for interfaces running at 400MHz or slower is to enable the high-performance Nios II-based sequencer instead of the RTL-based sequencer.
Updated 1 month ago
Version 2.0
