Knowledge Base Article
Serial Lite IV FPGA IP designs must be manually upgraded to IP version 5.5.4 in the Quartus® Prime Pro Edition Software version 25.3
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3, when opening a design that includes a Serial Lite IV FPGA IP version of 5.5.3 or earlier, you will not observe that Quartus automatically triggers the IP upgrade to the latest IP version 5.5.4.
Resolution
To work around the above problem, you should manually upgrade the Serial Lite FPGA IP to version 5.5.4.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.1.
Updated 3 months ago
Version 6.0No CommentsBe the first to comment
