Knowledge Base Article
Row *: Input field "Clock Freq. (MHz)" had an invalid import value of "1200.48". The field was defaulted to a value of "0" instead
Description
Due to a problem in the Intel® FPGA Power and Thermal Calculator (PTC) version 21.4 and earlier, you might see many occurrences of this warning after importing a .qptc file generated from a project that contains the External Memory Interfaces Intel® Stratix® 10 FPGA IP.
Resolution
These warnings can be safely ignored as they do not negatively impact the power calculation.
This problem is scheduled to be fixed in a future release of Intel® FPGA Power and Thermal Calculator (PTC).
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
