Knowledge Base Article
Quartus: Fatal Error: Segment Violation: faulting address=(nil), ... Module: quartus_fit
Description
Due to a problem in Intel® Quartus® Prime Pro Edition Software v21.1, you might see this error during the Fitter Retime stage. This error occurs when using an Intel Agilex® device where there is a critical chain on constrained I/Os.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software v21.1.
Download and install patch 0.01 from the following links:
Updated 4 months ago
Version 4.0
