Knowledge Base Article
Possible Syntax Error When Running Abstract PHY Simulation with ModelSim and Tcl
Description
If you run an abstract PHY simulation with ModelSim and certain versions of TCl, including version 8.4.11, a syntax error similar to the following may occur:
# extra characters after close-brace
# while compiling
# "lappend files {*}[ findFiles ]
# ("foreach" body line 2)
# while compiling
# "foreach dir {
# lappend files {*}[ findFiles ]
# (compiling body of proc "findFiles", line 4)
# invoked from within
# "findFiles "../../../../." "altera_emif_nios_forces_abphy.sv" "
# "join [ findFiles "../../../../." "altera_emif_nios_forces_abphy.sv" ] \n "
# "set force_files [ join [ findFiles "../../../../." "altera_emif_nios_forces_abphy.sv"
] \n ]"
# (file "altera_emif_check_abphy_nios_forces.tcl" line 34)
Resolution
The workaround for this problem is to do one of the following:
  • Type source from within the ModelSim command prompt, which will use a different version of Tcl.
  • Change the version of Tcl in use to a different version, such as 8.5.9.
This problem is fixed in version 15.1.1.
Updated 20 days ago
Version 2.0
