Knowledge Base Article
Performance Risk Running Triple Speed Ethernet LVDS in Arria 10 Devices
Description
There may be a performance risk if you use the Triple Speed Ethernet IP variant with LVDS I/O for PMA implementation in Arria 10 devices for Quartus Prime versions 17.0.2 and earlier.
Resolution
To avoid the performance risk, Intel® recommends that you regenerate the Triple Speed Ethernet IP core and recompile the design in the Intel Quartus® Prime software version 17.1 or later. Refer to the latest Triple Speed Ethernet User Guide version 17.1 for more information.
The following patch provides a solution to the Triple Speed Ethernet IP variant with LVDS I/O for PMA implementation in Intel Arria 10 devices for Intel Quartus Prime version 17.0.2. Download and install the appropriate patch from the following links:
- Quartus Prime Pro Edition software version 17.0.2 patch 2.05 for Window
- Quartus Prime Pro Edition software version 17.0.2 patch 2.05 for Linux
- Quartus Prime Pro Edition software version 17.0.2 ReadMe for patch 2.05
- Quartus Prime Standard Edition software version 17.0.2 patch 2.05std for Window
- Quartus Prime Standard Edition software version 17.0.2 patch 2.05std for Linux
- Quartus Prime Standard Edition software version 17.0.2 ReadMe for patch 2.05std
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
