Knowledge Base Article
On EPCQ-A devices, may the pins labeled “N.C” be connected to ground?
Description
Yes. In the EPCQ-A Serial Configuration Device Datasheet (version 2019.10.01) section 1.4.2, a note states that "N.C pins must be left unconnected." This is incorrect. The pins labeled "N.C" are not internally connected, and may be either not connected on the board or connected to ground. Connecting these pins to other signals or voltages has not been characterized or verified, and so is not recommended.
Resolution
The note in the datasheet is scheduled to be corrected in a future document revision.
Updated 3 months ago
Version 3.0
