Knowledge Base Article
make: nios2-swexample-create: Command not found
Description
Due to a problem in the External Memory Interfaces Intel® Stratix® 10 FPGA IP, errors may occur when compiling the Nios® II processor on-chip debug software if you enable the "Use Soft Nios Processor for On-Chip Debug" option using the Intel® Quartus® Prime Pro Edition Software v20.4 and earlier on Windows platform.
make mrproper
make[1]: Entering directory '/mnt/c/1/emif/ed_synth_20_4_0_72_onchipdebug_restored/ip/ed_synth/ed_synth_emif_s10_0/altera_emif_arch_nd_191/synth'
Deleting software ...
rm -rf software/software/emif_export_bsp
rm -rf software/software/emif_export_app
rm -rf software
make[1]: Leaving directory '/mnt/c/1/emif/ed_synth_20_4_0_72_onchipdebug_restored/ip/ed_synth/ed_synth_emif_s10_0/altera_emif_arch_nd_191/synth'
Creating hello_world_small create-this-bsp ...
nios2-swexample-create \
        --sopc-file=../../ed_synth_emif_s10_0.sopcinfo \
        --type=hello_world_small \
        --bsp-dir=software/emif_export_bsp \
        --no-app
Makefile:85: recipe for target 'software/emif_export_bsp/Makefile' failed
make: *** [software/emif_export_bsp/Makefile] Error 127
Resolution
To work around this problem, please use the Makefile instead.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software v21.2.
Updated 8 months ago
Version 4.0
