Knowledge Base Article
Is the timing model for Stratix® 10 1SX040, 1ST040, and 1SG040 FPGA devices correct?
Description
No, due to a problem in the Quartus® Prime Pro Edition Software v21.2 and earlier, the timing model for Stratix® 10 1SX040, 1ST040 and 1SG040 FPGA devices is not correct. This occurs because the timing model for vertical (C2/C3/C4/C16) routing wires are miscalculated. Errors range from few ps to 50 ps per path, with 150 ps in the worst corner for the worst wire. This problem only affects Stratix® 10 1SX040 (GX/SX H-Tile) / 1SG040 (TX E-Tile) FPGA devices.
Resolution
To work around this problem for projects using devices 1ST040xxxx (TX E-Tile), download and install the patch according to the versions of your Quartus® Prime Software.
Patch 0.60 for Quartus Prime Pro Edition Software v20.1:
Patch 0.57 for Intel Quartus Prime Pro Edition Software v20.2:
Patch 0.74 for Intel Quartus Prime Pro Edition Software v20.3:
Patch 0.43 for Intel Quartus Prime Pro Edition Software v20.4:
To work around this problem for projects using devices 1ST040xxxx (TX E-Tile) or 1SX040xxx (GX/SX H-Tile), download and install the patch according to the versions of your Intel® Quartus® Prime Software.
Patch 0.50  for Intel Quartus Prime Pro Edition Software v21.1:
Patch 0.30 for Intel Quartus Prime Pro Edition Software v21.2:
Once the patch is installed, perform the following actions:
  1. Save <design>.sta.rpt before running.
  2. Run quartus_sta –force_dat <project> in the command line.
  3. Recompile the design if there are any negative slacks.
This problem only affects the timing model for the devices listed. The other Stratix® 10 FPGA devices are not affected.
This problem is fixed beginning with version 21.3 of the Quartus® Prime Pro Edition Software.
Updated 12 days ago
Version 8.0
