Knowledge Base Article
Is the Intel® Stratix® 10 L/H-tile GXT channels On-Die Instrumentation (ODI) circuit performance preserved when not enabled during device operation?
Description
No. The performance of the ODI circuit of an Intel® Stratix® 10 L/H-tile GXT channel operating at data rates above 17.4 Gbps can degrade over time if it is not enabled full-time during the GXT channel operation. This problem does not affect the data path operation of the GXT channel. The performance of the ODI circuit of a GX channel at data rates 17.4 Gbps and below is not affected.
Resolution
If the ODI feature is required during the GXT channel operation, enable the ODI circuit full-time to preserve its performance by setting the following register bits for each transceiver channel. It is not required to perform an eye scan to preserve the performance. After 3 years, its performance at GXT channel data rates may not be preserved even if it is enabled full-time.
Change bits 2 and 0 of the GXT channel register address 0x168 from 1’b0 to 1’b1 via the channel reconfiguration interface to enable the ODI circuit.
To expose the reconfiguration interface ports, select the Enable dynamic reconfiguration option under the Dynamic Reconfiguration tab in the Native PHY IP.
To change the register through the system console, select the Enable Native PHY Debug Master Endpoint option.
For details, refer to Reconfiguration Interface and Dynamic Reconfiguration chapter in the Intel Stratix 10 L- and H-Tile Transceiver PHY User Guide.
For GX channels that are dynamically reconfigured to GXT mode, and if the ODI feature is required during GXT mode, enable the ODI circuit full-time whether in GX or GXT mode.
Enabling the ODI circuit full-time causes a power increase of about 90 mW on VCCR_GXB and 70 mW on VCCH_GXB per channel.
Updated 3 months ago
Version 3.0
