Knowledge Base Article
Is “s2f_cold_reset_reset_n” from Hard Processor System Stratix® 10 FPGA IP active low reset?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.1 and earlier versions, when you enable the “Enable HPS-to-FPGA cold reset output” option in Hard Processor System Intel® Stratix® 10 FPGA IP, a signal “s2f_cold_reset_reset_n” is exported in the top level.
The reset is not an active low reset but an active high reset.
Resolution
Please use the "s2f_cold_reset_reset_n" as an active high reset.
This problem has been fixed in Intel® Quartus® Prime Pro Edition software version 22.4 and later versions.
Updated 27 days ago
Version 2.0
