Knowledge Base Article
Internal Error: Sub-system: U2B2_CORE, File: /quartus/db/u2b2/u2b2_2wt_util.cpp, Line: 18
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4.1 and version 24.1. You will see the Internal Error(IE) shown above when using the Primitive DSP Native Fixed Point DSP Agilex™ FPGA IP with the operation mode set to m18x18_full and the Enable 'ax/bx/cx/dx/ex/fx' input register: and the Enable 'ay/by/cy/dy/ey/fy' or 'scanin' input register: options set to different values.
An IE will be observed if these options are not set to the same value, for example, if ena0 and ena1 are used.
All 'input registers' must be set to the same setting value.
Resolution
When the Primitive DSP Native Fixed Point DSP Agilex™ FPGA IP with the operation mode set to m18x18_full, all 'input registers' must be set to the same setting value.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 24.3.
Updated 11 months ago
Version 2.0
