Knowledge Base Article
Internal Error: Sub-system: PVAFAM_VISITOR, File: /quartus/power/pvafam/pvafam_titan_atom_visitor_main.cpp, Line: 2002 Atom type not supported by PVA
Description
Due to a problem in the Quartus® II software version 14.0 and earlier, when you use the Altera Advanced SEU Detection IP, Error Message Register (EMR) unloader IP, and/or Fault Injection Debugger IP in your design, you may see this error during the PowerPlay Power Analyzer (PPPA) or using Generate PowerPlay Early Power Estimator File.
Resolution
To work around this problem, download and install patch 0.109 from the links below. You must install Quartus® II software version 13.1 before installing this patch.
- Download the version 13.1 patch 0.109 for Windows (.exe)
- Download the version 13.1 patch 0.109 for Linux (.run)
- Download the Readme for the Quartus II software version 13.1 patch 0.109 (.txt)
This problem is fixed beginning with the Quartus® II software version 14.1.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
