Knowledge Base Article
Internal Error: Sub-system: PTI, File: /quartus/tsm/pti/pti_tdb_builder.cpp, Line: 5410
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2 and earlier, you might see this error when the cascade_out port of an IOPLL FPGA IP is connected to logic other than the refclk port of another IOPLL.
ATOM *|iopll_0|tennm_pll Type: FALCONMESA_IOPLL (atom id 309) with OTERM type O_PLL_CASCADE_OUT[0] does not lead to top-level port when it wants to reach ITERM type CLK[0] of ATOM
Resolution
To work around this problem, do not connect the cascade_out port of an IOPLL IP is connected to logic other than the refclk port of another IOPLL.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
