Knowledge Base Article
How to set HPS SDRAM PLL reference clock resource for Cyclone® V SoC device?
Description
In Cyclone® V SoC device, there are three clock sources for hard processor system (HPS) SDRAM phase-locked loop (PLL) named eosc1_clk, eosc2_clk and f2s_sdram_ref_clk, but it's not available to specify the clock source in HPS intellectual property (IP) GUI.
Resolution
The selection of clock source for HPS SDRAM PLL is controlled by Preloader software:
1. Generate spl_bsp from handoff files, and pll_config.h is generated in the "generated" folder of BSP target directory.
2. In the pll_config.h file, change the following value to the expected clock resource:
#define CONFIG_HPS_SDRPLLGRP_VCO_SSRC (0)
The value 0 means to use eosc1_clk as SDRAM PLL reference clock source, 1 means to use eosc2_clk and 2 means to use f2s_sdram_ref_clk.
3. Compile the Preloader and build the Preloader image.
Updated 11 months ago
Version 3.0
