Knowledge Base Article
How do I set the PLL compensation targets for the Altera_PLL megafunction?
Description
You will see the following warning in the Quartus® II fitter report if a PLL does not have a compensated clock specified:
Warning (177007): PLL(s) placed in location <PLL location> do not have a PLL clock to compensate specified - the Fitter will attempt to compensate all PLL clocks
                Info (177008): <instance_name> altera_pll:altera_pll_i|general[0].gpll~FRACTIONAL_PLL
Resolution
The way to specify a compensated clock target (which can be done directly in the ALTPLL megafunction GUI), is to make a “Match PLL Compensation Clock” assignment.  The syntax of the PLL clock node has to be specific in order for it to be saved in the Assignment Editor.  Filter on *outclk_wire* in a post compilation filter in the node finder.
For example:
example:inst|example_0002:example_inst|altera_pll:altera_pll_i|outclk_wire[0]
Where outclk_wire[0] corresponds to C0 in the Altera_PLL instance.
Related Articles
Updated 11 months ago
Version 3.0
