Knowledge Base Article
How do I resolve timing closure warnings when compiling a design with the JESD204C Intel® FPGA IP in base only mode?
Description
You may see some or all of the warning messages below when compiling a design with the JESD204C Intel® FPGA IP in base only mode in the Intel® Quartus® Prime Pro Edition software versions 20.1 or 20.2.
Message ID
Message text
17897
No destination clock period was found satisfying the set_net_delay assignment from "[get_keepers {mac_tx|j204c_tx_base_inst|j204c_tx_gearbox_inst|tx_gb[0].j204c_tx_gb_perlane_inst|tx_gb_fifo_inst|j204c_tx_dcfifo132b_m20k|dcfifo_component|auto_generated|delayed_wrptr_g*}]" to "[get_keepers {mac_tx|j204c_tx_base_inst|j204c_tx_gearbox_inst|tx_gb[0].j204c_tx_gb_perlane_inst|tx_gb_fifo_inst|j204c_tx_dcfifo132b_m20k|dcfifo_component|auto_generated|rs_dgwp|dffpipe*|dffe*}]". This assignment will be ignored.
332182
No path is found satisfying assignment "set_max_skew -from [get_keepers {mac_tx|j204c_tx_base_inst|j204c_tx_gearbox_inst|tx_gb[0].j204c_tx_gb_perlane_inst|tx_gb_fifo_inst|j204c_tx_dcfifo132b_m20k|dcfifo_component|auto_generated|*rdptr_g*}] -to [get_keepers {mac_tx|j204c_tx_base_inst|j204c_tx_gearbox_inst|tx_gb[0].j204c_tx_gb_perlane_inst|tx_gb_fifo_inst|j204c_tx_dcfifo132b_m20k|dcfifo_component|auto_generated|ws_dgrp|dffpipe*|dffe*}] -get_skew_value_from_clock_period src_clock_period -skew_value_multiplier 0.800 ". This assignment will be ignored.
332174
Ignored filter at intel_jesd204c.sdc(81): -group could not be matched with a clock
332049
Ignored create_clock at intel_jesd204c.sdc(64): Argument is an empty collection
332054
Assignment set_clock_groups is accepted but has some problems at intel_jesd204c.sdc(81): Argument -group with value -group {j204c_txphy_clk[0]} -group {j204c_txphy_clk[1]} -group {j204c_txphy_clk[2]} -group {j204c_txphy_clk[3]} -group {j204c_txphy_clk[4]} -group {j204c_txphy_clk[5]} -group {j204c_txphy_clk[6]} -group {j204c_txphy_clk[7]} could not match any element of the following types: ( clk )
332060
Node: j204c_txphy_clk was determined to be a clock but was found without an associated clock assignment.
Resolution
To workaround this issue in the Intel® Quartus® Prime Pro Edition software versions 20.1 or 20.2 replace certain lines in the intel_jesd204c.sdc file as shown below.
simplex rx base only(.../intel_jesd204c_rx_191/synth/intel_jesd204c.sdc):
    change from:
        77                           set overall_clock                  ""
        78                           for { set j 0} { $j < 4} { incr j} {
        79                           append overall_clock "-group {j204c_rxphy_clk[$j]} "
        80                           }
        81                                           set_clock_groups -asynchronous -group {j204c_rx_avs_clk} -group {j204c_rxlink_clk j204c_rxframe_clk} $overall_clock
    to
        78                           set clock_grp      ""
        79                           for { set j 0} { $j < 4} { incr j} {
        80                           append overall_clock "-group {j204c_rxphy_clk[$j]} "
        81                           }
        82                           set clock_grp_tmp {set_clock_groups -asynchronous -group {j204c_rx_avs_clk} -group {j204c_rxlink_clk j204c_rxframe_clk} }
        83            append clock_grp $clock_grp_tmp $overall_clock
        84                           eval $clock_grp
simplex tx base only(.../intel_jesd204c_tx_191/synth/intel_jesd204c.sdc):
    change from:
        63           for {set i 0} { $i < 4} {incr i} {
        64                           eval {create_clock -name "j204c_txphy_clk[$i]" -period  3.945ns           [get_ports j204c_txphy_clk[$i]]}
        65           }
        78                           for { set j 0 } { $j < 4} { incr j} {
        79                           append overall_clock "-group {j204c_txphy_clk[$j]} "
        80                           }
        81                                           eval {set_clock_groups -asynchronous -group {j204c_tx_avs_clk} -group {j204c_txlink_clk j204c_txframe_clk} $overall_clock}
    to
        64            eval {create_clock -name "j204c_txphy_clk" -period  3.945ns           [get_ports j204c_txphy_clk]}
        79              set clock_grp      ""
        80              append overall_clock {-group {j204c_txphy_clk} }
        81              set clock_grp_tmp {set_clock_groups -asynchronous -group {j204c_tx_avs_clk} -group {j204c_txlink_clk j204c_txframe_clk} }
        82              append clock_grp $clock_grp_tmp $overall_clock
        83                             eval $clock_grp
duplex base only(.../intel_jesd204c_tx_191/synth/intel_jesd204c.sdc):
    change from:
        64                                           create_clock -name "j204c_rxphy_clk[$i]" -period  3.945ns           [get_ports j204c_rxphy_clk[$i]]
        65                                           create_clock -name "j204c_txphy_clk[$i]" -period  3.945ns           [get_ports j204c_txphy_clk[$i]]
        66                           }
        86                           set overall_clock                  ""
        87                           for { set j 0 } { $j < 4} { incr j} {
        88                           append overall_clock "-group {j204c_rxphy_clk[$j]} -group {j204c_txphy_clk[$j]} "
        89                           }
        90                                           set_clock_groups -asynchronous -group {j204c_tx_avs_clk j204c_rx_avs_clk} -group {j204c_txlink_clk j204c_txframe_clk j204c_rxlink_clk j204c_rxframe_clk  } $overall_clock
    to
        65                           }
        66                           eval create_clock -name "j204c_txphy_clk" -period  3.945ns           [get_ports j204c_txphy_clk]
        87                           set overall_clock                  ""
        88                               set clock_grp      ""
        89                               append overall_clock {-group {j204c_txphy_clk} }
        90                               set clock_grp_tmp {set_clock_groups -asynchronous -group {j204c_tx_avs_clk} -group {j204c_txlink_clk j204c_txframe_clk} }
        91                               for { set j 0} { $j < 4} { incr j} {
        92                               append overall_clock "-group {j204c_rxphy_clk[$j]} "
        93                               }
        94                              set clock_grp_tmp {set_clock_groups -asynchronous -group {j204c_rx_avs_clk} -group {j204c_rxlink_clk j204c_rxframe_clk} }
        95                                append clock_grp $clock_grp_tmp $overall_clock
        96                                                           eval $clock_grp
note: all the clock period values are dependent on user selected values.
This problem is fixed starting with Intel Quartus Prime Pro Edition software version 20.3.
Updated 1 month ago
Version 2.0
