Knowledge Base Article
How do I enable debug endpoint for transceiver toolkit (ADME) for the F-Tile 25G Ethernet Soft-IP to use the Transceiver Toolkit?
Description
The F-Tile 25G Ethernet IP (alt_e25_f) does not expose the "Enable debug endpoint for transceiver toolkit" option in the IP Parameter Editor GUI. As a result, users cannot enable Transceiver Toolkit access through the standard IP configuration interface.
Resolution
To enable debug endpoint for transceiver toolkit for the F-Tile 25G Ethernet IP, use the following workaround:
To enable the debug endpoint for the Transceiver Toolkit, use the following workaround:
  1. Open the .ip file for the F-Tile 25G Ethernet Soft IP.
  2. Locate the ENABLE_ADME_GUI parameter.
  3. Change its value from 0 to 1.
  4. Save the .ip file.
  5. Regenerate the IP.
Note: This workaround modifies a hidden parameter that is not officially available in the GUI. The parameter implementation may change in future releases. After upgrading Quartus® Prime software, verify that the functionality continues to operate as expected.
Updated 4 months ago
Version 2.0
