Knowledge Base Article
How do I calculate the frequency, phase shift and duty cycle for clocking ALTLVDS soft SERDES using external PLL mode?
Description
Altera® devices have two types of implementation for SERDES blocks - hard SERDES and soft SERDES (built from logic cells). This document will discuss how to calculate the frequency, phase shift, and duty cycle for each of the clocks needed for the external PLL interface with soft SERDES. By selecting external PLL mode, you must set the PLL parameters, but you can access other features of the PLL such as clock switchover, PLL reconfiguration, and other output clocks which would otherwise not be available when using the internal PLL.
Download this How-To document to learn how you can calculate the frequency, phase shift, and duty cycle for each of the clocks used for external PLL mode with soft SERDES.
Related Articles
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
