Knowledge Base Article
How do I address known software issues for Stratix® V, Arria® V, and Cyclone® V devices in the Quartus II software version 12.0 SP2?
Description
There is a single patch available to address known software issues for Stratix® V, Arria® V, and Cyclone® V devices in the Quartus® II software version 12.0 SP2.
This patch will be updated periodically with the latest software fixes. Check here periodically for updated files. You can refer to the readme file for the date the file was updated and a list of software fixes.
Resolution
Download and install the Stratix V/Arria V/Cyclone V device patch 2.dp10 from the appropriate link below. You must install the Quartus II software version 12.0 SP2 before installing this patch. Note that you should not install any non-Stratix V/Arria V/Cyclone V patches on the Quartus II software version 12.0 SP2 after installing this patch. Patch 2.dp10 includes all the fixes from previously-released patches 2.dp2, 2.dp3, 2.dp4, 2.dp5, 2.dp6, 2.dp7, 2.dp8 and 2.dp9. You can install patch 2.dp10 over previous device patches, but you do not need to install previous device patches before installing 2.dp10.
- Download the version 12.0 SP2 patch 2.dp10 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp10 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp10 (.txt)
To install a previously-released version of the Quartus II software version 12.0 SP2 Stratix V/Arria V/Cyclone V device patch, select the appropriate link below.
- Device patch 2.dp9
- Download the version 12.0 SP2 patch 2.dp9 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp9 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp9 (.txt)
- Device patch 2.dp8
- Download the version 12.0 SP2 patch 2.dp8 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp8 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp8 (.txt)
- Device patch 2.dp7
- Download the version 12.0 SP2 patch 2.dp7 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp7 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp7 (.txt)
- Device patch 2.dp6
- Download the version 12.0 SP2 patch 2.dp6 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp6 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp6 (.txt)
- Device patch 2.dp5
- Download the version 12.0 SP2 patch 2.dp5 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp5 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp5 (.txt)
- Device patch 2.dp4
- Download the version 12.0 SP2 patch 2.dp4 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp4 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp4 (.txt)
- Device patch 2.dp3
- Download the version 12.0 SP2 patch 2.dp3 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp3 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp3 (.txt)
- Device patch 2.dp2
- Download the version 12.0 SP2 patch 2.dp2 for Windows (.exe)
- Download the version 12.0 SP2 patch 2.dp2 for Linux (.tar)
- Download the Readme for the Quartus II software version 12.0 SP2 patch 2.dp2 (.txt)
Related Articles
- How do I generate programming files for Arria V D7, B7, and B5 devices in the Quartus II software version 12.0 SP2?
- Why does Design Space Explorer only show two effort levels for performance optimization?
- Internal Error: Sub-system: ASMGX, File: /quartus/comp/asmgx/asmgx_stratixv.cpp, Line: 480
- Why might my Stratix V PCIe Gen 2 design intermittently downtrain to Gen1 speed?
- Internal Error: Sub-system: ASM, File: /quartus/comp/asm/asm_bit_connect.cpp, Line: 494
- *** Fatal Error: Stack Overflow, TIS_RE_DELAY_TREE_TRANSIENT_NODE
- Why do reads from my Altera PLL Reconfig megafunction fail?
- Why do I see different fitting and timing results when I recompile my design in the Quartus II software version 12.0 SP2 and earlier?
