Knowledge Base Article
How can the EMIF Debug Toolkit support multiple Agilex® 7 FPGA EMIF Interfaces?
Description
In the Quartus® Prime Pro Edition Software version 20.2 and later, the EMIF Debug Toolkit can support multiple EMIF Interfaces in the same or different rows by following the guidelines in the "Configuring a Design to Use the Toolkit" section in the External Memory Interfaces Agilex® FPGA IP User Guide.
Also, please ensure all the IPs are added to one .qsys file.
Note: USB-Blaster II should be used when using the EMIF Debug Toolkit.
Resolution
There is no workaround currently, and there is no plan to fix this problem.
Updated 4 months ago
Version 6.0
