Knowledge Base Article
How can I program the UFM with a hex/mif in Intel® MAX® 10 devices without impacting the CFM?
Description
To program the User Flash Memory (UFM) with hex/mif in Intel® MAX® 10 devices without impacting the Configuration Flash Memory (CFM), do the following.
Resolution
  1. Open the Convert Programming Files utility in Intel Quartus® Prime software
  2. Choose internal configuration in mode category.
  3. Go to Options/Boot info and select UFM source as load memory file.
    1. Choose a File path for your  .hex or .mif file.
  4. After this process, add the SOF file to the main conversion window and generate *.pof file.
  5. Open Intel Quartus Prime Programmer.
  6. After proper recognition of the Intel MAX® 10 device, add the previously generated *.pof file and set Program / Configuration to UFM (only).
Updated 3 months ago
Version 3.0
