Knowledge Base Article
How can I find an explanation for the SYNOPT_FULL_SKEW, RST_CNTR, and CREATE_TX_SKEW parameters in the Low Latency 40- and 100-Gbps Ethernet Intel® FPGA IP core simulation testbench?
Description
The following simulation parameters in the Low Latency 40- and 100-Gbps Ethernet MAC and PHY Intel® FPGA IP testbench file are not explained in the user guide.  Refer to the following definitions:
SYNOPT_FULL_SKEW - Support full skew tolerance according to IEEE spec. In the testbench example, this is turned off to speed up the initialization time.
RST_CNTR - controls the reset delays for the PMA reset process. It is set to 6 in simulation to speed up initialization. Ignore this parameter for synthesis and keep the default value.
CREATE_TX_SKEW - Lane-to-lane skew in simulation.
It is important that you do not modify these parameters, otherwise simulation could fail. These parameters are subject to removal in future Quartus® II software releases.
Resolution
These definitions are not scheduled to be added to the documentation.
Updated 11 months ago
Version 3.0
