Knowledge Base Article
Failed to read ACL on /var/log/journal/ operation not supported
Description
SSH access to SOC systems running Angstrom may fail if a root password has been set on the SOC system, and the error above may be shown in the system message log / journal.
This is due to a problem in sshd if a root password has been set, and the default sshd configuration is in use.
Related Articles
To resolve this problem edit the ssh daemon configuration file /etc/ssh/sshd_config and update the line: “PermitEmptyPasswords yes” to “PermitEmptyPasswords no” , then reboot the board.
The “PermitEmptyPasswords yes” setting allows SSH to run with no root password set (the default), but causes problems if a root password has been set.
This is scheduled to be documented in a future release of the SoC EDS Handbook.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
