Knowledge Base Article
Error(23098): One or more blocks are configured incorrectly and will not have the desired functionality. --BCM instance name: pio_1_1
Description
You may encounter the below fitter error when designing with the Agilex™ 5 FPGA MIPI D-PHY IP in Quartus® Prime Pro Edition version 24.1 when using a specific reference clock frequency and bit rate combination.
Error(12274): A critical error occurred while the periphery placement was committed to the atom netlist. The atom netlist is now invalid, and the Fitter must be restarted.
Resolution
These errors are caused by an invalid combination of reference clock frequency and operating bit rate. These combinations will be removed in a future release of the Quartus® Prime Pro Edition Software.
Updated 10 months ago
