Knowledge Base Article
Error(20054): Channel < * > has rsfec enabled, < * > is not a legal rsfec location, < * > are possible rsfec locations.
Description
Due to the limitation of the CPRI Intel® FPGA IP core, you might see the error message above if you use more than one CPRI Intel® FPGA IP with RSFEC sharing in the Intel® Stratix® 10 FPGA E-tile and Intel Agilex® 7 FPGA E-tile.
Resolution
To work around this problem, avoid using the CPRI Intel® FPGA IP with RSFEC sharing.
Another workaround is to separately generate and connect the MAC and PHY structure so that the PHY IP can share a single RS-FEC location.
This problem will not be fixed in a future release of the CPRI Intel® FPGA IP core.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
